As there is no way to do the calculations onboard and in respect of the
high acquisition rates the task is definitely not trivial. Here is an
idea how to do that:
- Configure a counter of the 6115 for buffered event counting
- Configure the counter to count the sample clock of your analog acquisition (the counter will count with a rate of 3-4 MHz).
- Route the time step signal (your 400 kHz signal) to the Gate of the counter.
- Start the counter
- Start the analog acquistion
With this configuration you should get two arrays: One array contains
the analog data, the other one contains the counter data. The counter
data represents the indices in your analog data array where the time
step signal transitioned from low to high. With these data you can
decide which parts of the analog data array need to be summed.
Of course this works only as an offline analysis after the acquisiton
is finished. If you really need to do the summation with a rate of 400
kHz while the acquisition is running I think this will not be possible
with standard hardware. I think this is even too fast for the fastest
DSPs available but maybe someone else can comment on that.
Best regards
Jochen Klier
National Instruments Germany
