sample rates PCI 6220?
Hello
Short Question:
I use a PCI 6220 and Measurement Studio C++.
I want to display all sample rates in a listbox of my program.
I looked for a list of possible sample rates for this card and I found in the datasheet:
max : 250 000 S/s...
... there's no minimum?
I think the steps are defined: 250 000 / multiple integer... but this will offer a huge amount of supported sample rates - Is it correct?
what is the lowest value?
I have the same problem with the 6036 and the 4462 card.
the USB 9233 for example provides a list of possible sample rates in the datasheet...
Message Edited by phonoX on 06-10-2008 04:05 AM
(3,098 Views)
Hi!
The sample rate is not generated from the maximum sample clock (250kHz) but from the timebase clock (20MHz or specific for the card).
http://digital.ni.com/public.nsf/allkb/4BBE1409700F6CE686256E9200652F6B?OpenDocument
So you can achieve really a lot of different sample rates.
Best regards
Ken
(3,078 Views)
