sampling rate
Hello all
I am using NI PXI 6225 card in my application. I am having one problem such as when i used single channel single ended configuration, i can not get 250 kS as per specification. if i want to get 250kS/s using 6225 in single channel, What can i do for this anybody having example code which is able to do this application
please suggest me the perfect solution for this
thanking you
keyur makadia
application engineer
optimized solutions pvt, ltd
919879307825
(2,986 Views)
You could use a high speeed Data logger vi
See this Link
(2,968 Views)
