sbRIO-9607 programming utility?
is there a utility to program this board without using labview tools?
or
is it possible to get a copy of the schematics?
thank you
Fausto Bartra
(1,146 Views)
No, you can use FPGA Interface C API to interface with the bit file, but the bit file (.lvbitx) can only be generated using LabVIEW FPGA Module.
Why would you need the schematics? If you are looking to design the mezzanine board, you can refer to NI sbRIO-9607/9627 RIO Mezzanine Card Design Guide
https://tmesystems.net/
(1,137 Views)
