scan rate
Hello everyone
I read  PCI 6255 data sheet and it tells me that maximum sampling rate is 1.25 M samples/s and scan rate is 750 Ksamples/s.
Now if i read all 80 channels(single ended), what will be the sampling rate of each individual channel? i.e (1.25 Msamples/s)/80 or (750 Ksamples/s)/80?
and second is if instead 0f 80 single ended inputs, if i use 40 differential inputs what  will be individual channel sample rate?
(3,616 Views)
I f you have just one channel to read you can have 1.25 MS/s.
If you have n channels to acquire, you have a maximal frequency of 750 kS/s/ n.
It's the same for single or differential channels.
Wilfried.
(3,610 Views)
Hello Asim,
Just a thought
Try sticking to a single post for your queries.
It would not only make followup easier but also would serve as a 'one stop read' for any soultion seekers in future
Read Jaimie's post here for further information on your query
Dev
Message Edited by devchander on 01-09-2008 11:49 PM
(3,598 Views)
Hi ASIM_BATH,
If you have more questions regarding this issue please direct them to this forum: simultaneous sampling, this way we can centralize the information for this question in one place.
Jaime Hoffiz
Product Expert
(3,575 Views)
