screw connectors
What screw should I use to connect an r6868 cable to a PCI 6023E board. There are no suitable screws supplied with either and I cannot find a commercial version
(2,830 Views)
Hi GeoffH,
The following KnowledgeBase should give you the information you need. You’ll need to contact National Instruments  to order the screws.
Mark E.
Precision DC Product Support Engineer
(2,813 Views)
