07-05-2013 02:57 PM
I was running niDMM 2.5.2 on Fedora 15.
Everytime I ran niDMM_SelfCal function, it caused the following error:
Jun 25 18:33:39 localhost kernel: [99394.205259] d_set.elf[32442]: segfault at b77c6000 ip b779eca1 sp bfd53ed0 error 4 in libDevDmm.so.0[b7791000+1d000]
Any suggestion?
07-08-2013
03:34 PM
- last edited on
06-20-2024
01:30 PM
by
Content Cleaner
Hi Joue,
First, are you sure about NI-DMM 2.5.2?, the latest version I found for linux is NI-DMM 2.5
Now if you check the link below, Fedora is not supported by DMM 2.5.
What Linux Distributions Do National Instruments Drivers and Software Support
Now, if you are able to use it and you want to know which step you could take, you could try to fix the driver installation following the steps specified in the readme file.
Regards
Frank
