08-18-2007 05:29 AM
10-23-2007 07:57 AM - edited 10-23-2007 07:57 AM
The board amplifies the signal depending on your range setting up to -10 to 10 V in order to have the possibility to use the resolution more effeciently independent of the signal strength. Your card has four gain levels. The signal is then scaled back to the initial level. So let say that your signal is between -1 to 1 V. If you have the range set to -10 to 10 V no conditioning takes place and therefore you are not using all bits of resolution for your signal. So it is up you to set the appropriate range in the virtual channel.
Notice that the range should be adjusted to fit the signal after scaling.
Message Edited by Pelle S on 10-23-2007 07:59 AM
10-23-2007 08:35 AM - edited 10-23-2007 08:35 AM
Hello Pelle,
thank you for your answer.
so: setting the range in MAX is enough if I want that the board uses the most efficient resolution, right? I do not have to configure it in Labview, if I set up the range if MAX, do I?
Mensaje editado por Dani Pindado
10-23-2007 09:04 AM
Hi Dani,
You are correct. As long as you use the virtual channel specified in MAX. But if you create a new task in LabVIEW you need to specify the range there.
