set daqmx input to RSA not differential
I believe my 6024E pcmcia card is reading in differential mode. I am using LV example "Acq&Graph Voltage-Int Clk.vi" to control it. How do I change the input to RSE instead of differential?
I was able to easily set the input, Ai0, from differential to RSE using the Test Panel in MAX.
Thanks ahead of time.
(2,982 Views)
richjoh,
The terminal configuration is an input on the DAQmx Create Channel VI used in this example. Since it is not wired, it will default to your devices default terminal configuration, which in your case is differential mode. To change this, wire a control or constant to this input, and you should be able to select from the terminal configurations supported by your device.
Hope this helps,
Dan
(2,979 Views)
