set gain in DAQ PCI-MIO-16E-4
Anyone know how to adjust the gain in PGIA  of PCI-MIO-16E-4 board ?
regards
thanks!!!
(3,894 Views)
You set gain by adjusting the Channel Min/Max values or the Range High/Low properties in DAQmx.  A complete description can be found here:
Using Min/Max or High/Low to Set NI-DAQmx Channel Gain
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(3,891 Views)
Thank you very much Ben.
Sorry I have another question. I'm trying to combine the gain from the PCI-MIO-16E-4 and the gain of an amplifier SCXI 1102, This is to achieve higher
gain. As you know SCXI only 1 or 100, which adjusts using a DAQmx Channel Property Node. But I don't understand what is the gain value that I get with the DAQ as a function of the  max / min values. I attached the diagram that I used for this
Could you give me some tip or VI example about  this?
Thank you very much!!!
Regards
Adán
(3,879 Views)
Hi Tibu!
Maybe the following links will help you a little more, your DAQ Card is an E Series device:
http://digital.ni.com/public.nsf/allkb/0ED2569AACD12C2586256D82007AE1D5?OpenDocument
http://decibel.ni.com/content/docs/DOC-4034
Hope this helps, ill check your diagram and let you know.
Have a great day!!
(3,790 Views)
