settling time for PCI-6281
I am using the PCI-6281 for single channel acquisition at 600KS/s. For a current application I need to know how long the sampling 'gate' is open, i.e. how long is the sampling period and how long is the interval between samples (the two adding up to 1/600K = 1.67 microseconds).
Steve Cohen
Newton Photonics
(3,094 Views)
Hi photonbridge,
I found this article on ni.com that explains the how you can obtain the convert clock's rate. The convert clock is what is used to generate data acquisition. Here are some more resources:
Difference between Sampling Rate and Convert Clock
How Can I Slow Down the Convert Clock Rate?
Hope this helps!
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,076 Views)
