short bluescreen error and automatic restart
I had recently created an executable on a host PC. Our IT guy created a local.mode acccount for our production people to use.
At times, I get a short bluescreen error and automatic restart whe I turn the computer on. Atually the background is black not blue and lasts a second or so.
I attached what Microsoft says about it.
What can i do to fix this?
Scientia est potentia!
(2,908 Views)
Hello magyar,
Since when are you getting this error message? Is it since the time you have started using this executable? Also, could you please let us know about what your application is design to do? Is it using any National Instruments hardware? If yes, then which all and what version of the driver is installed on this machine? Is the application calling some external code using DLLs?
Does the computer work OK after it restarts after this crash? By looking at the screen shot that you attached, it seems that one of the software drivers for some hardware in your computer is malfunctioning. This could be any hardware. So I would suggest that you uninstall any hardware that you might have recently installed and see if you keep on getting this error message or not.
Chetan K
Application Engineering
(2,891 Views)
