simulation loop and mathscript
I need input five parameters to simulation loop from the mathscript , the mathscript will caculate the parameters  and update the parameter every simulation loop ,but it seems  the simulation loop only influenced by the first five parameters , how can i update the input parameters every simulation loop ?
(3,305 Views)
Hi Prairie View,
I'm not sure that I understand what you are seeing.  Could you post a screenshot of your code or the VI itself, so that I can understand the behavior that you are getting?
Justin Parker
Product Support Engineer
(3,288 Views)
