simulink driver for PCI-6132
I have an S-Series PCI-6132 analog input data acquistion card. I am trying to use it with Matlab's XPC target kernel, but they currently don't have a simulink driver for any S-series cards, is there a generic driver or a workaround so that I don' t have to get a new daq card?
Thanks!
(3,502 Views)
Jpalme,
 I did some research on the driver support between National Instrument’s PCI-6132 that you’re using with the third party device. From my understanding, you seem to note that the NI-DAQmx Support from Data Acquisition Toolbox does not seem to incorporate with the third party card.
 In which case, this software driver line is created and supported by MathWorks, Inc.®  and they should be able to provide you an answer about whether there is a workaround.
 If I’m mistaken or there is another resource you were referring to, please feel free to reply below.
Ali S.
Applications Engineering
MATLAB® and Simulink® are registered trademarks of The MathWorks, Inc.
Ali S.
(3,476 Views)
