simultaneous counter and analog task on usb-6008
Hi there,
does anybody have an example on how to acquire simultaneously counter and analog channels on a usb-6008 DAQ board? I know on this board there's no way to do hardware timing, so I would settle for the next best thing. Max sampling frequency 100Hz. I am using Labview 8.5 on windows xp.
Thanks in advance
Nunzio
(3,538 Views)
Hello Nunzio,
You are right when saying that B Series boards (6008, 6009) do NOT support hardware-timed single point sample mode.
Does My DAQ Device Support Hardware-Timed Single Point Sampling Mode?
Moreover, Counter Input and Analog Input Tasks run on different Timebases, so you won't be able to share same sample clock.
Let me know if you need additional help.
Have a nice day.
Matteo
(3,512 Views)
Do you have any exemples to run simultaneous counter and analog task on usb-6008, even if the data base are not the same.
Thank you
Joel
(3,302 Views)
Hello Joel,
I found this topic concerning your question:
Synchronize Encoder Counter Input and Analog Input
Let me know if it helps.
Best regards
Matteo
(3,277 Views)
