simultaneous multichannel acquisition with NI USB-6009 (for dummies!)
Hello everybody!
I have to make a continuous 6 channel acquisition using a USB-6009 using a sampling frequency of 5000 Hz (for example for a duration of 10 seconds).
I wrote a C routine to read the 6 signals and save them in a buffer (using the CFile Open and Write functions), but I'm a programming neophyte and when I make a complete acquisition the result is not right.
The problem is that I have not completely clear the meaning of the parameters (numSampsPerChan, readArray[], sampsPerChanToAcquire) in the functions (such as "DAQmxReadAnalogF64", "DAQmxCfgInputBuffer" or "DAQmxCfgSampClkTiming") and their relationships.
Please, someone tell my how can I set the functions to read and save the 6 signals!
Alessandro
(3,919 Views)
Hi A P,
About how daqmx functions works and how use them try reading this document.
If you need funcions prototypes please refer to Start>>all programs>>National Instruments>>NI-DAQ>>NI-DAQmx C reference Help.
Have a good day,
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(3,896 Views)
Thanks a lot for the reply, FiloP.
The problem is that I've just read the documentation, and unfortunately I'm not enough expert in C (but I had use it!), and I fear I'm making a very stupid fault or maybe I'm mistaken completely!
In the end I will have to visualize the signals with matlab (or matcad, or with a VC program), so I decided to write the samples in a binary file.
The result was good when I read from 1 to 3 channels, but it's wired using the complete system, and now I'm in a hurry to acquire this signals...
It's a problem of parameters or I used a wrong method?
Here what I wrote of importance:
    CString campioniS;
    CFile salva;
    salva.Open("DatiSalvati.bin",CFile::modeCreate | CFile::modeWrite | CFile::typeBinary);
    int32       error = 0;
    TaskHandle  taskHandle = 0;
    char        errBuff[2048]={'\0'};
    int32       i,j;
    time_t      startTime;
    bool32      done=0;
    char        chan[] = "Dev1/ai0, Dev1/ai1, Dev1/ai2, Dev1/ai3, Dev1/ai4, Dev1/ai5";
    float64     min = -10.0;
    float64     max = 10.0;
    char        clockSource[] = "OnboardClock";
    uInt64      samplesPerChan = 1000;
    float64     sampleRate = 5000.0;
    #define     bufferSize (uInt32)1000
    float64     data[bufferSize*6];
    int32       pointsToRead = bufferSize;
    int32       pointsRead;
    float64     timeout = 10.0;
    int32       totalRead = 0;
    DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,chan,"",DAQmx_Val_RSE ,min,max,DAQmx_Val_Volts,NULL));
    DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,clockSource,sampleRate,DAQmx_Val_Rising,DAQmx_Val_ContSamps,samplesPerChan));
    DAQmxErrChk (DAQmxCfgInputBuffer(taskHandle,100000));
    DAQmxErrChk (DAQmxStartTask(taskHandle));
    startTime = time(NULL);
    while( time(NULL)<startTime+10)
        DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,pointsToRead,timeout,DAQmx_Val_GroupByScanNumber,data,bufferSize*6,&pointsRead,NULL));
        totalRead += pointsRead;
        campioniS.Format("%d", totalRead);
        m_label.SetWindowText(campioniS);
        salva.Write(data,16000);
    salva.Close();
Thanks for every kind of support!
Alessandro
(3,885 Views)
There's several options for doing data acquisition with this device directly into MATLAB.  Do a google search for "MATLAB data acquisition" for some ideas.
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
(3,855 Views)
Well I'm sure of it, but my problem remains, 'cause I anyway had to write the VC program for the acquisition of the 6 signals and the creation of the binary file (unfortunately I can't bypass it).
I also tried to use the example found in:
National Instruments/NI-DAQ/Examples/DAQmx ANSI C/Analog In/Measure Voltage/Cont Acq-Int Clk,
but I can't come through to apply it to my VC task (it's a simple Dialog Box with an 'Acquire' button): I haven't a "main()", but a function for the acquisition:
void CProgramDlg::OnAcquire(),
and I don't know how to use the examples instead of the method I used applied to my application.
Please someone tell me how I can finish this work!!!
Thank to all.
(3,837 Views)
