simultaneous waveform generation from PXI 6713
Hi
I am using VC++ to develop my application
and I am using PXI 6713 DAQ.
I am trying to generate a 100 KHz waveform running out continously from one of the Analog Output Channels of PXI 6713.
Then I want to generate another waveform from other DAC channel, which has to get triggered, whenever the output of my DUT goes from LOW_TO_HIGH
For this, I've connected the PFI-5 line to my device output and configured the PFI 5 line so as to trigger waveform generation, whenever the PFI-5 detects a LOW_TO_HIGH.
I've used the command
Select_Signal (deviceNumber, ND_OUT_START_TRIGGER, ND_PFI_5, ND_LOW_TO_HIGH);
But when I do this, the first waveform from a DAC channel goes to a dc level and only when the PFI-5 gets triggered, the first channel resumes its waveform generation.
The second channel gets triggered and generates a waveform without any problem. But the problem is at the first channel.
My requirement is : I want a generate an independantly running waveform from one DAC channel. I want another DAC channel to generate a waveform, whenever it gets hardware triggered through PFI_5. It should not disturb the first channel.
(I have avoided Counter Ouput to generate waveform, since I am specific about Amplitude).
FYI, I am using FIFO mode operation.
Can any one help me in this regard.
Thanx in advance.
****** My code *******
void WaveGen1()
// Generate 100 KHz waveform from DAC 4
i16 deviceNumber = 6; // PXI 6713 Device Id as per NI-MAX
i16 deviceNumberCode; // to be returned by Init_DA_Brds function
i16 chan = 4; // DAC channel 4
i16 numChans = 1; // only one channel is used for
i16 chanVect[1] = {4}; // DAC Channel 4
f64 gain = 1.0;
i16 binArray[10] = {0};
i16 group = 1; // default for most of the devices
u32 count = 10; // 10 data points
f64 voltArray[10] = {0};
double voh = 2.0;
double vol = 0.0;
for(int i = 0; i < 9; i++)
voltArray[i] = voh;
voltArray[9] = vol;
u32 iterations = 0; // Repeat waveform for indefinite period
i16 mode = 0; // disable delay mode
f64 rate = 1000000; // 1,000,000 points / sec
i16 units = 0; // points / sec
i16 timebase;
u32 updateInterval;
i16 whichclock = 0; // update clock
i16 operation = 1; // Start waveform initiation
Init_DA_Brds (deviceNumber, &deviceNumberCode);
WFM_Scale (deviceNumber, chan, count, gain, voltArray, binArray);
WFM_Group_Setup (deviceNumber, numChans, chanVect, group);
WFM_Load (deviceNumber, numChans, chanVect, binArray, count, iterations, 1); // use FIFO mode
WFM_Rate (rate, units, &timebase, &updateInterval);
WFM_ClockRate (deviceNumber, group, whichclock, timebase, updateInterval, mode);
WFM_Group_Control (deviceNumber, group, operation);
} // End of the function
void WaveGen2()
i16 chan = 6; // DAC channel 2
i16 chanVect[1] = {6}; // DAC Channel 2
f64 gain = 1.0;
double voh = 2.0;
double vol = 0.0;
voltArray[i] = voh;
voltArray[9] = vol;
u32 iterations = 0; // Repeat waveform indefinitely
i16 mode = 0; // Disable delay mode
f64 rate = 1000000; // 100,000 points / sec
i16 timebase;
u32 updateInterval;
// configure PFI_5 to accept low_to_high trigger
(2,891 Views)
Hello;
Both Analog Output channels output data of the same buffer, and the pointer that address the buffer is the one that is triggered. You can't have pne Analog Output channel running while the second one waits for a trigger pulse, on the same DAQ device.
To accomplish that you will need to DAQ devices.
Hope this helps.
Filipe A.
(2,890 Views)
