slow operation
Some customers are experience intermittently a delay between the time my code
executes a NIDAQ command for AI scan and when the board executes the command.
We are using the PCI-6024E with Windows 95. I can't reproduce it on my system.
Has
anyone experienced something like this or have any ideas?
(3,453 Views)
> code executes a NIDAQ command for AI scan and when the board executes the
> command. We are using the PCI-6024E with Windows 95. I can't reproduce
it
> on my system.
> Has anyone experienced something like this or have any ideas?
How much is the delay (more or less)? Milliseconds? seconds?
Did you try the following:
- Switch the bios "plug and play os" setting
- Use a different IRQ
- Configure the device at a different device number
- Upgrade Ni-Daq to 6.7
- Remove all other PCI cards (network card, etc), see if it still happens
Hope it helps,
Walter van Iterson
(3,453 Views)
