smallest voltage change detectable
A simple question, but the help is appreciated.
My 6289 m-series ADC is 18 bit. I am performing AI Voltage with LV8.5 DAQmx Read (Analog 2D I32 NChan NSamp).vi
For +/-10V input range, is the smallest detectable voltage change:
10/(2^17)= 76.3 muV    ?
Thank you,
Frenk
(4,528 Views)
Hello Frenk
If you need to use this input range +/-10V:
20/(2^18)= 76.29 uV
Regards
(4,424 Views)
Thank you.
Frenk
(4,409 Views)
