software gain setting on DAQCard 6062E
I am tring to measure temperature with a K-type thermocouple from OMEGA and I am using SCB-68 terminal box. I have problem to read actual temperature. My chart shows a constant value of 1250 ? I have already tried the options single endet, referenced single endet and floating signal. No success, need help 😞
(2,650 Views)
Greetings,
I would suggest that you connect the thermocouple in a differential configuration. Differential channel 0 corresponds to pins 68 (positive) and 34 (negative) on your DAQCard-6062E (and SCB-68). Furthermore, to test the thermocouple, your best option is to create a virtual channel in Measurement and Automation Explorer (MAX) for a K-Type thermocouple.
Good luck with your application.
Spencer S.
(2,650 Views)
