source time delay
Hello All,
I'm using PCI-6250 to acquire two DAQ assistant signal, and one DAQ assistant to trigger those two.
Will the time delay occur (the two signal)?
thanks
(3,009 Views)
Hi Cedrick,
If the aquisitions both start from the same hardware trigger then there will be no delay between aquisitions.
However, if the aquisitions are merely running in paralel then there will be some inherent delay due to software.
Hope this is of use to you
Regards
Steve
(2,981 Views)
