speedy-33 maximum DSP capacity
I am new to Labview and Speedy-33. We currently working on a small project using biquads on the Speedy-33. For the moment, it work perfectly. Ideally, I would need 48 biquads to implement stereo octave band filters. I think that the DSP capacity limit is more about ~18 biquads (with a sampling rate 36kHz), at least according to my experience. Using 18 biquads, I think that I get some glitch indicating the max DSP capacity?
Does 48 biquads seems impossible on a single Speedy?
What would indicate me that I am exeeding the DSP capacity at 36kHz? What is the biggest filtering operation we can imagine on a Speedy-33?
Also, what may reduce my capacity is that use a table to store my coefficient. Maybay the routing of this table (with supplementary "index array" to extract the proper coef) consume even more computing time?
Thank you,
(2,829 Views)
Hi pagauthier,
Unfortunately, it is difficult to calculate the number of biquad stages that could be executed at 36 kHz on the SPEEDY-33 for a variety of reasons.  It doesn't surprise me, however, that the DSP is having trouble keeping up in real-time.
You could try using the DFD Filter Express VI (along with the Digital Filter Design Toolkit to design the filter) to design something that will have a better chance of running in real-time.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(2,795 Views)
