start a DAQmx PWM signal PCI-6032E
Trying to start a PWM signal after temperature values have been met.  The DAQ assistant acquiring to temp data works great.  The DAQ assistant 2 generates a high output on port 0 line 1... this works great.  However, once the temp value is met, I want to shutdown the DAQ assistnt 2 and turn on the DAQmx PWM process.  This is not working and generates errors or doesn't output the PWM to the ctr0 output port.  I am using an SCC-68 breakout box.
(2,791 Views)
What errors do you get, can you post a screen shot? Is it the same behavior every time?
Matt
(2,758 Views)
