stop dupgg
i am used in my project measurement studio and i have two timer one to draw graph and another to make calculate to give the graph timer it's data
(one timer dependent onthe other ) and whn i put build it gives me no error and it success but in the debug it stop automaticly
i dont know why ?
plz tell me
(3,562 Views)
when i,
So you have two timers in your project, and your project builds, but it does not run properly?  What language are you writing in? (C#, C++, VB)  Can you post some code of how you are doing this?
Eric B.
(3,542 Views)
i thax about your reply i used vb.net and measurement studio virsion 8.1
and i will tell u simple example take any example from anyproject and in the main timer writ simple code like out ($834,2)
and make debug
u will it run and the stop automaticly
and neally i will send u the code
(3,532 Views)
when i,
I tried implementing what you suggested, but I think I am not understanding completely.  Can you post some code that reproduces this error?
Eric B.
(3,497 Views)
Private Sub timer_plot_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles timer_plot.Tick
 dim s as double
s= out (&h34)
pressure_wave.PlotYAppend(s)
   End Sub
"s" is a double came from parallel port
and i need make update to data after each time
(3,489 Views)
I am not even able to build that code.  What is the out function you are referring to?  My compiler does not know where that is coming from.  Is this a driver function you are using?  What does the "&h34" parameter you are passing to it mean?
Eric B.
(3,467 Views)
