substituing the stand-alone instruments with VI using DAQ, is it possible?
hello everybody,
1)I am thinking to replace my PC-controllable pulse generator and 3 PC-controllable voltage supplies in my measurement set up with VI and instead to generate 1 pulse output and 3 dc voltage in AO of a DAQ. First I NEED you to confirm that it is possible??
2) if the mentioned set up is feasible, Do u have any suggestion for the DAQ type?
for more clarification, I describe my needs in details here:
I need a DAQ to generate  2 or 3 continuous DC voltage and 1 pulse output. The main issues that should be considered are as following:
1)the outputs should work individually
2)the dc volatge I need is one about 30volt and the other about 8 volt( I'm thinking about an amplifier but if signal conditioning can work, it would be great as well)
3) I know that initially the data will be saveed in buffer and then the output generation will start(in other words there is delay) and continues untill the specifications are changed or will be stoped by user,here my question is that if after any changes in specifications we counter with buffer delay? and if there any way to cancel this delay?or decreased it as least as possible?
4) I need one digital input for recieving a TTL pulse
I need at least 1.5Ms/s transfer rate and for sure a good price.
Ela
(2,895 Views)
