switch configuration for analog voltage from ao port?
what switch configuration is required to read an analog voltage from ao port?
(2,994 Views)
A DAQ card has no switches that need to be configured for analog out.
(2,979 Views)
sukhiray,
All of the connections are made by the underlying DAQmx driver when you select a certain Device name and Channel.  Here is a tutorial which shows how to build an Analog Output VI for further clarification.
(2,953 Views)
