I am trying to measure the response time (around 1ms) of the pressure drop indicated by AI channel 0 when the AO channel 0 gives a negetive single pulse to the unit under test (valve). DAQ board: Keithley KPCI-3108, LabView Version: 6.1, OS system: Win2000 professional.
My problem is I am getting different timed graph between the AI and AO channels every time I run my program, except the first time I can get real time graph. I tried to decrease the buffer size less than the max buffer size of the DAQ board (2048 samples), but it still does unreal time graph from AI channel, seems it was still reading from old data in the buffer when AO writes the new buffer data, that is my guessing. In my p
rogram, the AO and AI part is seperated, AO Write buffer is in a while loop while AI read is not. Would that be a problem? Or it's something else?
Also, I am trying to measure data much larger than the board buffer size limit. Is it possible to make the measurement by modifying the program?
I really appreciate any of your help. Thank you very much!
Best,
Jenna
