synchronization S-series PXI 6123 and SC series PXI 4220
(I already posted this question in the Labview forum without much reaction as that was the most appropiate forum for this question)
Dear,
I have to synchronize 2 DAQ boards in a PXI rack.  After some searching on the internet I'm a bit confused, there seems to be a lot of different solutions to solve the problem ... but it depends on the actual configuration of the set-up.  I would like some advice which solution is the most suited:
I have in a PXI rack the following boards:
PXI NI 6123, S Series Multifunction DAQ  (responsible for capturing 5 analog signals with also the triggering channel)
PXI NI 4220, SC Series DAQ With Signal Conditioning  (1 full bridge connected)
Software: labview 7.1 and NIDAQmx 7.1
If this is working, I'm going to write everything in Matlab code such that I can do the measurement directly from Matlab (this is already working for only the PXI 6123 card)
Kind regards,
Peter Vleugels,
Message 1 of 1
(2,832 Views)
