synchronization
Hi
Anybody has an idea of how to verify synchronization of  different PXI cards.
I have   2 PXI 4472(AI) cards and one PXI 6713(AO). i want to syncrhronize all the cards.
I am thinking of syncrhonizing all the analog inputs  with  the onboard clock of  6713 card.
I dont know how to verify
Help needed!!
Vilas G
(3,092 Views)
Vilas,
Please refer to this KB on synchronizing DSA and S series cards.
I would recommend that you one of the DSA boards as the master and export the sample clock to the S series card.
You can check to see if everything is synchronized by sending a signal to a channel on all boards and checking to see if the samples are aligned.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,089 Views)
