synchronizing pulse generation(output) and analog waveform ouput using 6221
Hi,everyone
I am a new one in DAQ, thank you for your help in advance!
I am trying to output a continuous periodic triangular waveform to drive a galvo mirror, which frequency is about 30Hz. And a TTL pulse train with the same frequency(30Hz) must generated to trigger a external device by its rising edge. The problem is that how can I synchronize the two signals? I can generate the two signals separatly using AO and counter.
Thank you!
帖子被witchball在03-16-2008 02:41 AM时编辑过了
Message 1 of 1
(2,942 Views)
