thermocouple graphs
Hi all
 Can anyone have the standard thermocouple graphs of J,K,R,S,T,N,E and B. The graphs can be on MATLAB or labview and also please tell how can i use the low pass filter on labview . Basically, due to some noise my actual result is distorted. for example , if the actual temperature is 200 C then it is varying from 190 to 205 C. How can i get the stable output?
(3,089 Views)
the conversion vi;s should be somewhere in the signal processing....
press Ctrl-Spacebar and type in thermocouple....   or better 'volts to temperature'
Browse the exsamples : Help - Find Exsamples ... - Analysing and Processing Signals - Filtering and Conditioning
Greetings from Germany
Henrik
LV since v3.1
(3,072 Views)
