Sir,
I am using the PXI 6143 multi function S - series DAQ mx card. I want to generate three phase PWM using the digital line outputs. The fundamental frequency is 50 Hz I may need to go up to 100 Hz. that means 20 ms to 10 ms per cycle of sine waveform. with in this 10 ms I need to produce PWM of say 100 samples (10000Hz sampling rate). But after developing the code with timed loop , the minimum dt is 1 ms. So is there any way to code it in Labview.
DSpace I am using for generating the PWM output with micro seconds precision. But in Labview Is it possible or not.
