times value in waveform to spreadsheet
Hi!
Could I send to spreadsheet the times value generate by waveform chart/graph?? Together with the y-axis values,Thanks
(2,588 Views)
Perhaps you could try reading your data as a waveform instaed. If you are using the DAQmx Read VI, this is selectable by choosing from the drop down menu on the bottom of the VI. How are you reading your data, and what are you using to write your data to a spreadsheet? You first need to check that time information is being made available, then ensure it is written to a file.
(2,580 Views)
