timing sample and data display
I want timing record signal and stamp time(ymdhms). There are two problems attached my.vi  as below:
1. The x-axial display  isn't accordant with the system time. why is this ?
2. How to display the data with current system time, i.e. the current data are separated by interval?
THKS!
(3,749 Views)
Do I not clearly describe the problem?
Give me a suggestion,please!
(3,736 Views)
Hi,all
Help me please!
Thanks!
(3,712 Views)
Since I have LabVIEW 8.0 on my system , I could not take a look at your vi ( built on higher version of LabVIEW)
However look at this attached vi
You will find it in examples shipped with LabVIEW, Find Examples>>Fundamentals>>Graphs and Charts>> Real-Time Chart.vi
It plots data on a chart with current time/system time X axis.
Hope this helps
Dev
(3,709 Views)
