transmit and receive digital in the same VI
Hi
  Now what I confused is that if I can generate a digital waveform, and which can be received by waveform in the same VI. The hardwire is PXI-6259, which has two terminals, one of which is out put terminal and another is input terminal, the signal is transmitted through the wire which connect two data terminals. What I did is right? And I do not know how to use the external clock ,if I use the internal clock, the signal can not be collected. Who can help me, thank you!
Vivian
(2,889 Views)
Yes, you can do this, if you can share your code?  we'll find out.
(2,868 Views)
