06-02-2008 08:57 AM
06-03-2008
05:09 PM
- last edited on
06-21-2026
11:07 AM
by
Content Cleaner
In general, one of the PFI lines can be used as an external digital trigger.The USB 6211 has external digital triggers through PFI<0..3>&PFI<8..11>.
If synchronization is needed throughout the whole acquisition process with the external clock, the external clock can be used as a clock source for the DAQ device.
For more information on the USB 6211 check the specification manual. If you are using windows xp, a good example to start with can be found at
Start menu>>All programs>>National Instruments>> Measurment studio for visual studio 2005>>visual C++ examples >> Analog In >> ContAcqVoltageSamples_ExtClkDigStart
Faris A.
06-04-2008 10:31 AM
This is a good example for external trigger on AI0 and external sample clock other pin, but the data that is read is on AI0.
How can I read and capture data on a different AI or DI when the trigger event occurs on AI0?
Do I need to create another task and have it triggered from the same source?
When I do this I get errors about resoruces not availabele or not available.
Not sure how to trigger on AI0 and capture data on another pin.
Any other examples on how this would be done?
Tech Products
06-05-2008 04:01 PM
The example accepts a digital trigger on PFI0( pin 11) , while AI0 is pin 68.
Nevertheless, since the 6211 accepts triggers at PFI 0 - PFI3 and PFI8-PFI11 , you can select any of those as a trigger source. Also, you can choose acquisition on any of the AIs.
The same code can be used , but you have to set the appropriate channel names for your specific hardware connection. I recommend reading the program description when you open the C++ code.
Faris
