trigger restart analog task
hello
im using the PCI-6221 68 Pin Card, I have to write out analog signals synchronized with a rotary encoder.
my problem is: i have to start writing out the buffer from the beginning after receiving a the Z-Impuls signal.
how can i force the analog output task to reset and start writing out from the beginning
the Z-Impulse signal arrives after every 2000 samples
im using the A-channel as my sample clock to write out the analog signals
im using DAQmx VI's
thanks a lot
greets chris
Message 1 of 1
(3,044 Views)
