trigger
HelloI wonder if there any body can help me. This is the first time for me to use the LabView, as I want to use the DAQ USB 6008, my problem as the follow
First of all the circuit am working on consist of MUX and operational amplifier , what I want to do is to read the output voltage from the OP/Amp via the USB 6008, and send the MUX address using the USB 6008, I can use the LabView to read the voltage, but I don’t know how to use the trigger as I want to read the output voltage from the op/amp for each  channel of the MUX per time, and how can I use the trigger also to send the MUX address at the same time.
am using labview 8.5Hope to help meThank you all
(3,128 Views)
This is a duplicate of this thread.
Please post one thread on the same topic at one time.
Message Edited by Tom O on 08-28-2008 11:49 AM
Tom
Applications Engineering, NI UK
(3,113 Views)
