troubles with daq
I’m using my device in differential AI mode and I have connected a differential input signal, but my readings are random and drift rapidly...
(3,099 Views)
Which DAQ are you using?
And I hope that you are addressing all the points mentioned in these Links
Field Wiring and Noise Considerations for Analog Signals
Which Mode Is Best for Measuring Floating Signal Sources?
Which Mode Is Best for Measuring Grounded Signal Sources?
(3,087 Views)
