true false and signal
hello,
i have a problem of get out a signal from
no-error condition, false condition in my vi.
in stand alone program i might be able to
shows my temperature signal but in my
full system i cannot see the data.
did i miss something in the loop
or wrong do of wiring? thanks for the help
and i really appreciate it.
Ni LabVIEW 7.1
UTHM
MALAYSIA
(2,792 Views)
I noticed a few things in your VI:
1. You are wiring a single data point (Mean X 100) to your waveform graph indicator. Do you wish to display the DAQ input signal or the mean value of this signal on the graph. In case you wish to see the mean, then I would recommend you to use waveform chart so that you can see the history of the Mean of the datapoints.
2. Similarly for the Temperature Status, you are overwriting the values on the waveform graph for every iteration of the loop. You should replace your waveform graph indicator with a waveform chart indicator.
I hope this helps!
Mehak D.
(2,770 Views)
