Hi gg,
I'm assuming you have an E series DAQ card installed on your machine to communicate with your bnc board and you have LabVIEW 7.0. If you want to basically invert the behavior of your line, you can do this in Measurement and Automation Explorer (MAX). First, create a New DAQmx Task and set it up for a Digital I/O Line. Once the task is created, you can then click on it, and see it's task panel come up on the right side of MAX. Here, you can enable the Invert Line setting to behave as you would like. If you are using Traditional DAQ, then create a new Virtual Channel set for Digital I/O and invert the line.
Hope this helps!
Jeremy L.
Jeremy L.
