two channel frequency measurement with NI USB 6259
I am currently measuring a pulse frequency using the "high frequency two counters" approach on a NI USB 6259.
Is it be possible to use an external trigger for the counters (setting the measurement time) in order to measure simultaneously two pulse frequencies on ctr0 and ctr1 ?
I have no idea how to do so with DAQmx
Marc
(2,832 Views)
problem solved with two edge counters triggered by the same clock
(2,814 Views)
