two different analog inputs
I'm using a DAQCard-AI-16E-4. I'm reading in 6 analog input voltages from
ACH0-5 which are digitally triggered by a pulse signal at PFI0. So one set
of voltage data is acquired when a pulse activates it. I modified "Acquire
N - Multi-Digital Trig.vi" to do this.
However, I want to also read another single analog voltage from ACH6 at a
continuous rate without a trigger.
Is this possible and how do go about doing this?
(3,170 Views)
I don't think that you can do that because of the fact that there is only on clock on board and that has to be generated once the trigger comes.
Abdullah
(3,170 Views)
