unable to add the network device
Hi
I am facing problem to add the network device.In max window, when i search for the connected network device , it automatically recognises NI DAQmx-9191 but the button to " add the selected device" is disabled. I can not add it. Please help . why it is like this ?
(4,122 Views)
Hi panthripu
Which version of NI-DAQmx you have installed?  You’ll probably need to upgrade to a newer version of the driver. Take a look at this article.
Regards
Chris S.
(4,092 Views)
i am not sure at this moment but i believe it is 5.0. The model numerb is NI 9234 and surprisingly , even after the insturment is connected to my computer throught ethernet and the power of the instrument is on , i can not see it from by computer by pinging.
(4,077 Views)
You need to upgrade your NI-DAQmx version, you can download the latest version from here.
Chris S.
(4,064 Views)
