unable to find DAQmx on distribution
I attempted to build an application using LV8.0 and incorporating DAQmx as I have often done.   This time, however, I get a 'distribution missing' prompt indicating that the installer source for N_-DAQmx 8.0 cannot be located.   This is despite inserting the correct CDs (distribution November '05) when prompted to do do.
I have removed and reinstalled labview but the problem persists.
I would appreciate any ideas.
Best regards
(2,996 Views)
Hi Mike,
This seems like a reasonably common problem so there is a Knowledge-Base article on our website regarding the ‘distribution missing’ prompt:
I hope that this helps to you, but let me know how you get on.
Kind Regards,
Ian
Message Edited by Ian Colman on 10-29-2007 05:39 AM
(2,978 Views)
Hi Mike,
Did you have any luck with the KB that I recomended to you?
Ian
(2,942 Views)
