undefined error in executable
I have build an application + installer and installed it on a stand alone machine. All works perfectly, except that some error codes are stated as undefined, e.g. -20307, an analysis error. "Install custom error codes" has been checked (-20307 is not a custom error). How do I get error codes to be defined?
Rgds
Gerwim
Message 1 of 9
(5,148 Views)
Hello Gerwin,
Can you please attach your installer, so I can have a look at  the error?
Casper
Message 2 of 9
(5,126 Views)
How to attach something to a message? There is no option in the button bar.
Gerwim
Message 3 of 9
(5,122 Views)
Reply on this message and at the bottom you will find Add Attachment.
grtz casper
Message 4 of 9
(5,120 Views)
The installer is too large to send. Here is the project file.
Is it possible that error codes are not copied if they are "borrowed" by my own vi's?
Gerwim
Message 5 of 9
(5,115 Views)
Helloo Gerwim,
Which version of LV do you use, 8.6 Proffesional Development? Do you use any Signal Processing VIs?
  • Install custom error code files—Includes LabVIEW error code files in the installer build. LabVIEW includes all files in the labview\project\errors and labview\user.lib\errors folders that end in *-errors.txt. Remove the checkmark from the checkbox if you do not want to include error code files.
    Note  You must manually create an errors folder in the labview\user.lib directory to organize your error code files.
  • With kind regards,
    Casper
    Message 6 of 9
    (5,096 Views)
    I'm back again.
    The error list from which I use codes is in:
    C:\Program Files\National Instruments\LabVIEW 8.2\resource\errors\English
    As you can see I use 8.2.1
    Since these are 'standard' errors, they should be copied.
    I'll copy the files to the userlib-error folder
    Gerwim
    Message 7 of 9
    (5,032 Views)
    Hi
    Copying files from the resource\errors folder to the project\errors folder made thing work.
    So the problem is solved, but I'm not very happy with it.
    Gerwim
    Message 8 of 9
    (5,028 Views)
    Hello Gerwin,
    First the best wishes for 2009!
    Indeed, this is an unexpected behavior. Do you have the same problem creating a simple executable, can you reproduce it?
    With kind regards,
    Casper
    Message Edited by CasperK on 01-05-2009 02:34 AM
    Message 9 of 9
    (4,922 Views)
