undefined reference to (pci-5105)
I have a pci-5105 running on a Win32 system. I have searched the forums and online about this problem and was not able to find any solutions that worked. I am trying to compile and run the example "MultiRecordFetchMoreThanAvailableMemory" function in C. This is the function that came with the driver. When I try to compile it I get the following two errors:
MultiRecordFetchMoreThanAvailableMemory.c:(.text+0x2b): undefined reference to 'niScope_GenericMultiRecordFetchMoreThanAvailableMemory@0'
MultiRecordFetchMoreThanAvailableMemory.c:(.text+0x19f): undefined reference to  'asciiPlot@8'
I have tried using 3 different compilers (currently using MS Visual Express C++), moving all of the header and c files to the same directory, going through each function line by line, etc. I am not able to figure this out and this is really putting a dent in my project.
Any advice would be greatly appreciated.
Best,
James
(3,045 Views)
Hi jwm1,
Could you please try running and compiling the attached program?  Perhaps something in your programs could have been messed up.  The program that I have attached is a shipping example and has been tested and worked many times.  If this does not compile, you may need to uninstall and reinstall NI Scope and try to compile/run the program again.
Jim Schwartz
(3,022 Views)
