unexpected error in MAX after imported configuration
I had installed an application that on an other PC we have been using for several years. I had installed driver for GPIB-USB-HS from the companion disk.
After I had manually imported the content of the MAX from the older host PC to the PC with the new installation I get
an "Unerxpected Error - Measurement & Automation Explorer" message
further down in the window I see :
"The AsstntUI.mxx plug-in caused an exception in the CmxAggregateItemUI::GetViews function in the NIMax process. See this file for details: C:\ProgramData\National Instruments\MAX\Logs\20120911_160041-NIMax-00000EA0.log"
How do I fix this?
Scientia est potentia!
(3,899 Views)
Thanks for the report, could you also include the two machine's OS info and MAX versions?
Have you tried exporting to a different file type and try importing?
Systems Engineer
SISU
(3,888 Views)
Exported MAX config from old PC: XP 32bit; Max 4.6.2 to USB drive.
New PC: Win7 64bit;
MAX was installed by application Installer : MAX 4.6.2
I did not yet try to expost teh MAX config as *.ini, or *.txt yet.
I'll try that next.
(3,882 Views)
Also, which versions of NI-VISA and DAQmx do you have installed on each?
Systems Engineer
SISU
(3,880 Views)
Nathan,
I had finished installing all the drivers on the new system from my drivers disk that came with the most recent developer suite update.
This solution is probably not the quickest but it worked.
Everything seems to work now.
Thank you for your time and attention.
(3,877 Views)
Great!  I'm glad that you got it working!
Systems Engineer
SISU
(3,864 Views)
