unflattening data and reading from usb device
hi,
i´m trying to read flattened data after writing some commands to a daq usb device without success. what i did was to unflatten the data and chose type i16 becuase i know the device sends two bytes per point. i get numbers that are definitely wrong and out of range.
i would appreciate any help,
thnx
(2,856 Views)
Could you please explain better your application? Wich device are you using?
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(2,781 Views)
