unsupported module error with cDAQ 9174 and 9207module
unsupported module means i cant use 9207 module in cDAQ 9174? is it hardware problem? not software?
(1,058 Views)
NI-9207 is compatible with cDAQ-9174. Reference: C Series Module and CompactDAQ or CompactRIO Hardware Compatibility with LabVIEW
What are your Windows and NI-DAQmx driver versions?
https://tmesystems.net/
(1,036 Views)
hi, thank you for your reply
this is my computer and program setting
1. window10
2. labview2015 32bit
3. daqmx 15 version
I have a question
when I use daqmx 15version, I can use DAQmx assistance for measuring flow rate in labview but I can't use  ni9207 module with unsupported module message.
so I upgrade daqmx 15 to 18.6 then DAQmx assistance couldnt use in labview it disappeared but ni9207 connected, in ni max I can check.
1. should I downgrade version of daqmx? which version can capable to labview15 32bit ,cDAQ9174 and 9207module?
2. or is there other problem in my setting?
I can't upgrade my labview version cause my school license
I want to measure flow rate
(1,003 Views)
I always recommend using the latest supported version, which is NI-DAQmx 18.6 in your case.
I also don't recommend using DAQ Assistant. Use NI-DAQmx API instead. See How to Search DAQmx Examples in LabVIEW
(982 Views)
I appreciate it
ill do
(941 Views)
